tachometer wire colour?
  • hermanio
    replied
    my tacho shows 1/5 to much rpm. what could cause this problem ? (4cylinder swapped for 5 cylinder turbo with s2 tacho)
    replied
    That must be MAC05 ECU then... I dont know if the tacho from a 7A engined coupe is compatible with rpm signal from that ecu...
    Checked the wiring and it is definitely black/violet wire from pin 7 on KG ECU for rpm.
  • spink
    replied
    Wtf is KG engine ?
    10vt from audi 200,182bhp
    replied
    Wtf is KG engine ?
  • osha
    replied
    already tried that, but it didn`t work. maybe the violet-black isn`t right wire from KG ECU?
    replied
    When rpm signal gets to cluster it is a green/blue wire - look for it on pin 22 of the YELLOW 26-pin plug in the cluster
  • osha
    replied
    purple - black comes from KG`s ECU, but what color wire in panel is for tacho?
  • Pirvu Eugen
    replied
    purple....
  • osha
    started a topic tachometer wire colour?
    Hello, can anyone tell me in what color are wire for tachometer?
    i replaced my 7A engine with KG turbo engine and i cant figure out witch wire is for tachometer..
