Revs dropping when lifting off
    replied
    Check the idle switch on the tps is being triggered too
  • sidrick
    replied
    Originally posted by UrS4boy
    Audi PN 035919369M or Bosch Bosch 0280130037?
    That's what I've bought, yeah
    I'll be doing a bit of a sensor refresh along with the timing belt in a couple of weeks.
    replied
    Originally posted by sidrick
    Certainly sounds similar to my issue. I should have said, I have a '91 3B.... does this sensor exist on my car? **Looks like it does and for the price of the one you linked on eBay I might as well switch it out.
  • sidrick
    replied
  • Thuppu
    replied
    Worth a try: http://www.s2forum.com/forum/showthread.php?t=59449
  • sidrick
    started a topic Revs dropping when lifting off
    After changing the ICV on my car it now idles well (well, okay) but ever since I've had it I've had a problem with the revs dropping to stalling levels when changing gear or just reving in neutral. I.E. When shifting from 2nd to 3rd gear I put the clutch down and the revs drops to an indicated 2-300rpm before it stabilised.
    It sounds like an air leak to me, but has anyone experienced similar?
