I5 extreme! spoke with jonus about my engine, and general discuss
  • vcosmin
    replied
    Dutter racing, has listed 9200 rpm, in his 2.5 stroker, it has a gt42, now upgrading to something larger , curenttly around 1000hp. Also, i have my engine unopened for 2 years, and still holding, reving to 8500rpm, rpm and sometimes hitting 9000rpm (first gear) with 95.5 cranck and long block. For rod ratio, there are some high reving hondas with 1.5x ratio, like type R B18C , and it holds fine. So it works, but depends on if is worth it or not, maybe with a close ratio gearbox in 8500 rpm, is more than enough, for almost any turbo setup.
  • |CL|NIKI
    replied
    With Gtx 42 or bigger?
    Are only 86,4 can we rev to at list 9000rpm? What about 95,5 or 100mm?
  • repo
    replied
    Hydraulic lifters collapse somewhere above 8500RPM, even when modified solid.
    Did Jonus tell why not to use 92.8 stroke?
    We have done 10 000rpm, but only with 86.4mm.
    All of who have not tried +9000rpm revs, I assure You, it is not as simple as changing rev limiter, especially if You have setup that flows and turbo that keeps pushing full boost at those revs.
    I am not saying I doubt +9000rpm with stroker, but I would love to see some evidence. Stroker + proper flow and proper boost at 9000rpm should be outrageously powerful. Mind we got almost 1200hp on dyno and +1300hp on track from 2.2 liter and 9600rpm.
  • |CL|NIKI
    replied
    Originally posted by my2000apb
    all this high rpm talk makes my hydro lifters tireds
    At high rpm there is no problem wit filling the lifters with oil. The problem are the springs - they cant return the valves. That's why we put strongest one. And the valve seats - to do not burn, or/and make valves jump. That's why we use beryllium copper. For guides too. That's my opinion...
  • |CL|NIKI
    replied
    Originally posted by JP
    I'm running 236block 95.5 crank lightened to weight of 86.4crank. Rod ratio of 1.66 and rev to 8000+rpm on stock oil pump. If I went dry sump I quite happily take that to 9500 peak 9000 continuous.
    At a push I'd say 10,000 but the head wont shift the correct airflow to support it on a turbocharged stroker without enlarging valves. Whereas in an ideal world at that rpm you want to keep stock valve size or even smaller to help lighten the valvetrain for high rpm.
    Hth
    There is a 5.5mm stem intake valves mate .
  • my2000apb
    replied
  • JP
    replied
    Hth
  • terrybullwon
    replied
    Originally posted by Acidburn
    And whatever your budget, take that and either double or at least triple it.
    What he said
  • Acidburn
    replied
    Originally posted by terrybullwon
    I remember being told this once by
    Take this in mind and then get a blank bit of paper and start a fresh
  • terrybullwon
    replied
    Originally posted by One wise man
    How fast can you afford to go?
  • my2000apb
    replied
    Originally posted by will20v
    Jonus has been there and done it take his advice.
    agreed
  • |CL|NIKI
    replied
    I will go same way this spring. Will use diesel block, diesel crank, H beam rods 158 or 159mm. + 83mm pistons and 4th stage dry sump pump.
    Some time ago I asked here in the forum, and it became clear that 9000 RPM are no problem even with original oil pump, but with CrMo wheel.
    But I will go to a dry sump and mechanical lifter + at list 1mm oversized valves and fuly headwork/port.
  • will20v
    replied
  • cooperquattro
    replied
    What was the point in asking if don't follow his advise??
  • donce
    replied
    not so many people know this stuff if speaking about 9k rpm, not to mention the Diesel crank! at such high rpm. you could also ask Repo and then make your decision
