low oil pressure - sender wiring?
  • Avantus
    • Sep 2007
    • 941
    • Country: Belgium
    Hi all,
    I've got a oil pressure sensor that's reading up to 0.8bar lower on revs compared
    with a mechanical gauge. I know these gauges are not te be trusted, but
    the sender is new. The only strange thing is that I still sometimes have the needle
    swing off the scale. Simply hitting the wires near the sensor normally makes the
    reading work again. Now, could the dodgy wiring also have more resistance causing
    the reading to be low, or do these gauges also go faulty?
    Thanks!
