Injector Connector PN 443906232 issues (or potential issues)
    The fuel injectors and a bunch of other devices in the engine bay are connected to the engine harness via a 2 pin (female pin) connector, PN 443906232. This is Item 11 in this engine bay harness diagram (there are a bunch of devices that use this connector):
    Andy P (here on the S2Forum) had issues with a miss on his ABY S2. Naturally we gave him lots of ideas (coils, plugs, connectors, etc etc). Eventually, he fixed his problem by doing a bunch of things at the same time (plugs, better ground(s) and fixing a wiring issue at one (two?) of the injectors. It is likely that the issue was the injector wiring (where did we here *that* one lately)(1gcrazy's miss was based on broken injector wire).
    Here is what a hopefully good injector connector (one of mine) looks like (note the purple plastic pin holder):
    Here is a shot of one of Andy P's good purple pin holders:
    Photo courtesy of Andy P.
    Here is a shot of one of Andy P's bad pin holders:
    Here is another shot of a bad pin holder:
    It is easy to imagine the possibility of the two wires going to the fuel injectors touching (arching) in one of those bad pin holders, causing a lean mis-fire (not enough fuel in that cylinder).
    Andy P replaced the bad pin holders with a new one-piece two pin connector like this one:
    Bottomline: We now have another thing to check when misses are experienced. (Sorry) :-(
    Hints on dealing with the purple pin holders are found in this POS pin swapping post:
    This info is also in my fuel injector wiring post:
