idle timing vcds
  • freakytate
    • Jun 2014
    • 206
    idle timing vcds
    hi, vagcom is throwing a throttle idle switch fault. also noticed my timing at idle is i think 16-18btdc where as vagcom suggests 8-12btdc. im presuming the issue is linked. will this cause slight pinking.....
    i need to go in another stock ish s2 to know whats what and whats not with engine noises and spool / boost behaviour.
