Are they TS tuning chips? Sounds very similar to a problem i had. If they are TS chips they store 100's of fault codes once powered up for the first time. Once the codes are cleared the issues will disappear. Mine used to rev to a similar rpm then hard cut, and rpm needle used to bounce of zero.
If i rem correctly it took a few attempts to get vcds to connect to the ecu, but once it did connect it connected first time every time there after.
