Where to put my air filter?
  • #16
    50% joke and 50% of a working intake pipe. I had that setup swivelled below the intercooler so that the aircleaner was positioned on the left side airvent, where the ambient temp sensor is located. 1 meter of 3" plastic drain tube did the trick.
    Have to say that I did not really feel any difference in the lag department with my Holset after I took the long tube off the intake for this current setup.
    When the car was tuned we had the airfilter sticking straight out from the turbo where the right headlight normally sits. Would be the best place but little too provoke...
    S2 Avant SleeperWagon 570hv and 765nm on 2,2bar/E85
    • #17
      Originally posted by A80Avant View Post
      Other than potential turbo damage, fitting a simple mesh on the turbo, isn't that the most optimal 'air intake'?
      Not if you're still using a MAF on the intake side.
      91 Modded 3B
      14 A6 Avant Black Edition
      • #18
        Originally posted by s2dk View Post
        steve h nice setup do you run a snub mount behind the ic?
        A shortened snub mount is still there, but only for crank locking. I have solid engine and gearbox mounts, so the snub mount isn't required anymore.
        91 Modded 3B
        • #19
          Okay. I was just wondering. I dont have mine on at all. Never had an issue
          • #20
            This is ny setup. Fittet af slightly bigger filter. On Second picture
            What power are you running also what filter is this do you have part no
            • #21
              Atm 565 hp and 600 nm
              you Can get it at burgertuning.com
              http://www.burgertuning.com/single_t...er_by_BMS.html
              • #22
                On vems
                • #23
                  Hi, does this filter cope with the heat from the turbo? I have melted 2x K&N filters installed directly on the turbo cold side.
                  Regards Leif-H.
                  Leif-Helge
                  -91 S2 VEMS and Comp Turbo
                  -12 B** 530XD Touring "S2 parts transporter, and daily driver"
                  • #24
                    Yah it is made specific for that problem. So it Will not melt at all. I have about 15000 km on the first one and nothing Wrong with it
                    • #25
                      Internal DIA looks to large for my turbo cold side
                      • #26
                        It fits a 4” intake
                        • #27
                          My twin bmc filter. Have bought air filter socks too
                          This gallery has 5 photos.
                          • #28
                            Same location I had mine in originally. I had to lift mine as the filter got wet when the car was jet washed and I knackered the MAF.
                            91 Modded 3B
                            • #29
                              And where is the oil cooler?
                              I cant use that position due to a larger oil cooker sitting there
                              • #30
                                Its behind the front grill
