Scalars with same nomenclature
  • Scalars with same nomenclature
    Hello community,
    this is my first post. I have a S2 with 3B engine and did a conversion to AAN ECU with this great speed density mod. (Thank you for that prj !)
    I am curious about some scalars regarding the LC/NLS code with same nomenclature.
    Unfortunatley I do not have the skills to disassemble the code to look for myself yet. So I would need your help.
    Can you please tell me why there are two scalars for:
    -Launch control IGN retard RPM @ 0x861E vs. 0x8625
    -Launch control IGN angle @ 0x8624 vs. 0x862B
    -min RPM for NLS @ 0x8636 vs. 0x863D
    -IGN angle for NLS @ 0x863C vs. IGN angle for NLS/Spark revlimit @ 0x8643
    -Speed for launch control @ 0x8620 vs. Speed for launch control #2 @ 0x7E7C
    Thank you!
    With best regards
    It's because there were many different patch versions a.
    Open the view by "category", then you will see that the old ones are in a separate "old" folder.
      I did not know the view by "category". Now it's clear.
      Thank you very much for the explaination and great to see that you come over here from time to time!
        Special Greetings for DD
        Thank you very much for the explanation and great to see that you come over here from time to time!
        In the left upper corner there is drop down menu named "View by:". There you can select parameter "category"
        Best regards
