Track day suspension geometry
This is a sticky topic.
  • Pirvu Eugen
    replied
    Originally posted by diesel des
    The problem is the Muppets that use the kit. And for health and safety your not allowed in the workshop bs.
    i know the feeling!!
  • diesel des
    replied
    Originally posted by Rusty
    Any garage with a lazer alignment setup can do it, it's just getting the ramp for an hour or two that's the issue. Anywhere that does race cars will be able to help I'm sure.
    replied
  • diesel des
    replied
    That explains it. None really about here.
    replied
    I get it done at a local motorsport place that has a full lazer alignment setup.
  • diesel des
    replied
    Once I have the new transmission mounts, I'm going to pull the subframe to realign the bushes, as the updated design twisted when fitting, due to the gearbox mounts not being loosened and so no extra castor was achieved. Then it's time to finish this little project. I have decided upon the following settings:
    Front
    • 2.3-2.5 Deg Camber
    • 4.0-4.5 Deg Castor
    • 0.0-0.5mm toe in
    Rear
    • 1.0-1.2 Deg camber
    • 0.5-1.0mm toe out
    The range is because the values achievable are dependent on which method I choose to use to achieve the settings. I am looking for maximum reliability and am not keen on camber bolts on the front, having had the M14 bolts loosen in the past at the 'ring
    This should dial out most of the stability, that I found to be a little too sanitised on track, while maintaining the improving steering weight and front grip.
    These settings may change as/when I go to a coilover setup and can chose spring rates to dial out the understeer, rather than using a massive rear bar. A coilover setup would also allow me to adjust the roll centre balance front to rear.
    Other than the castor, all these settings are achievable on a stock car, so anyone can try them out without the need to spend £00s on new parts. Max stock castor is about 2.5 deg. to achieve this, you need to rotate the balljoints as far forwards as possible on the slotted holes.
    What do you use to measure toe, camber and importantly caster? I have kit to do tow and camber but caster looks like it will make my head hurt.
    replied
    Front
    • 0.0-0.5mm toe in
    Rear
    • 0.5-1.0mm toe out
    replied
    Update from the weekend's track time:
    The car is still very stable and neutral (more so than a fast road setup B4 sedan) and now only has a touch of understeer under power and a nice hooked-up feeling on neutral throttle mid corner.
    The rear camber is still too high and the rear spring rate a little low, robbing some adjustability but what it does do is carry decent speed through the corners and I was on the power very early, meaning corner exit is very good with the line opening out a touch at WOT in 3rd followed by good grip when reducing the steering angle as the corner unfolds. Stability under braking is excellent, even with the toe out at the rear and steering weight is good with a small amount of extra feel over stock.
    The front is now as extreme as I'd want and the rear either needs more spring rate and roll centre or less camber to bring back some fun and adjustability.
    It's still a slow in fast out car but more corner speed and more stability on exit have improved the overall lap time if not the slippy slidey grin factor it had as standard.
    Plans for the future depend on springs & damper choice but on the current setup, I know what I'm going to settle on for a combined setup.
    On my own I was seeing 1m22/3s lap times from the video footage of the back of my head . That compares to 1m30s a few years ago on raod tyres, with standard turbo and standard suspension.
    replied
    Thuppu is your man there - he's done some custom parts to get the geometry sorted.
  • orignalS60
    replied
    Anybody ever start a thread like this but for the urs4/6
    chassis. It would be cool to hear about some track day
    specs for other models.
  • jade
    replied
    Originally posted by 20v
    So Any Setup That It Is Ok For A Track Day?
    Think you need to read the thread
  • 20v
    replied
    replied
    Ah, stripped out rear does change things somewhat...
  • diesel des
    replied
    Camskills have the whiteline arb for 144. One is on order.....
  • diesel des
    replied
    Thanks for the advice rusty. The white line bar is on my list to get. But as my car is a Urq with s2 running gear completely stripped out with race seats and a full cage there are enough variables that I will try the 60n springs and work from there. I reckon I should be able to get the car to 1250kg ish.
    So we're is best for the whiteline bar?
