have you seen what happens when a cast iron flywheel fails.... OUCH!!!
Anyway.. thanks for all your help folks, I may be back LOL
Hi I need all your expert help with flywheels
Well total 70€ for 7A flywheel and getting it a bit lighter, compared to 399€ + shipping € for ccc motorsport flywheel, i'd say i still have a LOT more imptrant things to do than loose another 4Kg from my 10.45Kg flywheel
wow 10kg is still real heavy, id say 7kg is ideal.
If any of you guys want lightweight flywheels go to this guy!!
http://www.ccc-motorsport.de/online-...category_id=66
The 7A flywheel should be 12Kg, I also had the clutch surface reworked and backside machined down, got it to 10.45Kg, witch should be enough for daily use, whilst still beeing a lot lighter that stock AAN dualmass(ca 14KG)
It's been said the 3B is the lightest, anyone put and actual figure to it in Kg.
Looking at a lightened flywheel possibly next year but do not want anything radically lighter that it upsets the normal running. Cheers
Originally posted by BenC30 View Post
ah i see the pin now... ill have a look when i get back to work, i certainly didnt spot a pin like that, wonder if its fallen out.
Originally posted by spink View PostNM and 7a uses the same flywheel,that part number you gave IS a 7a/NM flywheel,the chance of finding an NM engine is the UK is slim to non anyway
Right , I would of helped if you had taken the photo from the top as you may be hiding the pin from the angle of the photo , however from the diameter of the ridge I don't think there is a pin so it is most likely an NG .
For reference here is a pic of the back and front of a 7A flywheel, note the pin on the back next to the ridge and the diameter of the clutch contact surface on the front.
ah so 10v version of the 7a! So does the NG have a 230mm clutch and the 7a has a 240mm??
