Problem with 3rd gear
  • Gorrol
    • Apr 2008
    • 6
    Hi,
    I just changed clutch and slave cylinder after a breakdown.
    After reassembling the gearbox with the engine i have problem shifting in to 3rd gear.
    All other gears are no problem when the car is stationary.
    There was no problem with shifting into 3rd gear before i removed the gearbox from the car.
    Do you think this problem will solve itself after i start i up and get the gears moving?
    Or is there a real problem with the 3rd gear?
    Because if it is its for sure easier to fix it before i put all the stuff back on.
    // Andreas
