034 gearbox an engine mounts?
  • G60Rallye
    replied
    Originally posted by malncol
    ok so if iam going to use 034 track density edit motorsport spec gearbox and engine mounts along with ally subframe bushes there is no need for a snub?? bare in mind using for rally
    thanks
    mal
    I run without the snub mount yes. I have the sump guard supporting the sump with a piece of rubber between which adds support. However I would still happily run without that with these mounts, they dont let the engine and gearbox move.
  • malncol
    replied
    are yep i stuffed that up mine are the motorsport spec ones like the new one in your photo
    thanks
    mal
  • Laaf
    replied
    This is what the Track Density mounts looked like when I took the engine out. Both gone into two.
    Using these mounts now, 034 Motorsport spec mounts. I'm also using these on the gearbox. I haven't taken the car yet for any road tests, wheels are still in the air, but I don't think they make alot more sound than the track density ones.
  • malncol
    replied
    Originally posted by G60Rallye
    Thats exactly what I make of them! They hold the engine and gearbox solidly and means you can run without the snub. I dont think they give out many vibrations either.
    thanks
    mal
  • ADP
    replied
    thank you mates!
  • Thuppu
    replied
    I got quite a lot of clutch and gearbox rattle, but thats just motorsport. Custom polyu. engine mounts, 034 polyu. snub mount, 034 track density gearbox mounts, alu/steel subframe bushings.
  • G60Rallye
    replied
    Originally posted by Pembo
    Hard. No, better than that, SOLID! Ideal for me. Not for standard road use though. Almost over engineered. I have given them some abuse and with both engine and gearbox mounts there is no movement in any direction so no need for that front snub mount.
  • GazzaG60
    replied
    i used track density on the road. great mounts. i used with alloy subframe and poly rest and promount ms1 topmounts.
    fantastic road setup with the correct shocks and springs. i had koni.
  • Pembo
    replied
  • ADP
    started a topic 034 gearbox an engine mounts?
    some one wich use track density gearbox and(or) engine mounts on s6 c4?any opinion of this items?
    thanks!
