Thanks for the information. I have an Audi 90 Quattro box in the garage that I bought about 10 years ago from Spink. If I recall the first gear was taller than the silly low coupe version. Does anyone know the ratios for 5th on both boxes at all please?
David
6 speed onto 7A engine what parts are needed please?
Don't forget that you will also need front axles as the 7a has smaller inner joints & different lengths.
ChrisLeave a comment:
back!
Gearbox, subframe, mounts, prop and linkage for a 6 speed conversion. Works fine with a 7A flywheel and clutch.
As Rocco says, 3B is the same top gear and should work with all the existing parts.Leave a comment:
If I were you I'd rather to use 01A ARV 5speed box from S2 3b
Just will be a direct replacement and you'll improve your fuel economy with the longer ratios
By the way,I've one for sale if you want
I'm doing a classic car rally next year in France in my Coupe Quattro 20V and wish to fit a 6 speed gearbox into my 1990 Coupe Quattro 20V. it's the same shape as the S2 but non turbo and has the 7A engine.
My current 5 speed gearbox has horrible front diff noise. I also wish to improve the economy as I have 2000 miles to travel in a week!
Parts list:
6 speed box,
maybe matching differential if the ratio is different..
Dual mass flywheel?
gear linkage
if anyone can help with information please, Corey Pm'd me with a list of parts required about 10 years ago but I can't find it...
DavidTags: None
