Here's food for thought. This info comes from factory manuals on 3B and ABY engines regarding QUANTITY of fuel delivered by each injector.
With control hose disconnected on FPR in each case -
3bar nominal pressure on 3B
4bar nominal pressure on ABY
The fuel pressure under vacuum conditions on the control hose is 0.5bar lower in each case - confirming my view that the regulator is a stepped device.
In BOTH the 3B and ABY engines, the factory spec is for 160ml (+/- 10ml) fuel delivery per injector over a 30 second period. That gives a rating of 320cc per min - at 3bar on the 3B and 4bar on the ABY.
That means the 3B injector actually flows more fuel than the ABY item at the same pressure, assuming linear behaviour of course, but that is fair enough.
I can only presume that the ABY injectors work better as the four jet pattern is more effective than the single jet of the 3B injectors.
Paul
Paul
