are the engines the same as s2 it's the facelift 100 shape. are they aby same as the s2 avant just wondering for power increase chips etc
s6
Originally posted by Audi_CQS6 got AAN engine. Mostly same as ABY except IM.
It has an earlier version of the direct ignition system than the ABY, but still runs a distributor which I gather can be a pain to adjust.
Cheers n
Si95 ABY S2 Coupe - Ragusa Green
Subtle mods here and there
2011 A5 3.0 TDi - Lava Grey
With every option available (except a towball)
Originally posted by HPmuirtThe AAN was the predecessor to the ABY and sits half way between the 3B and the ABY in terms of development.
Cheers n
SiCorey
01636 822288
accoriding to performance data aan engine has maximum torqe 350, meanwhile aby has 380(overboost) . i guess then that ann dont have overboost function, it may have also lower orignal boost limit? could anyone correct me, if i am wrong......Audi Coupe S2 1993
Audi V8 4.2 1993
Audi cabrio 1998
Originally posted by valjoaccoriding to performance data aan engine has maximum torqe 350, meanwhile aby has 380(overboost) . i guess then that ann dont have overboost function, it may have also lower orignal boost limit? could anyone correct me, if i am wrong......
You can clearly see it working on a (analogue) boost gauge.Corey
01636 822288
Yes urs4/s6 have overboost, as mentioned only a few early 92's have the dizzy setup, almost all dont.
One thing i dont like on our s4 is the intercooler, much smaller than the S2 item.
Mark.91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express
Originally posted by mcandmarOne thing i dont like on our s4 is the intercooler, much smaller than the S2 item.
http://www.034motorsport.com/product...roducts_id=218Corey
01636 822288
Originally posted by CoreyThe '92 AAN did indeed have the dizzy but after that it is the same spec as the ABY (except it's fitted in a better car ) and the front facing inlet manifold.
The AAN short block is the same as ABY short block, ancillary bolt-on's differ, but one is not better than the other.1990 Coupe quattro 20v, no T
1992 S4 20v, very much so T
Originally posted by inc13and sump aswell ,im using aan converted to aby in my car
btw s4/s6 (aan) has small IC ,and its p.i.t.a. to put bigger IC in this car
Originally posted by merlin's S4This won't work with UK 100 S4s! The US versions have a different, deeper front bumper. Although it may work with the S6 bumper.1990 Coupe quattro 20v, no T
