Noticed part of the engine bay gettin oily recently so finally decided to take some action.
oil had began to seep down into the spark plug area so following instructions on S2-audi.co.uk (sorry, couldnt find any on the forum) removed the cover and fitted the new gasket kit.
Part no. A034 198 025 F
outer rubber seal seemed ok, but inner rings around the spark plugs had baked solid which explains why they were letting throu oil. had to be broken off from
cam cover.
Also found earth strap at rear of cover was loose, so all in all a job well worth doing.
Brian
cam cover.
Brian
