Noticed part of the engine bay gettin oily recently
so finally decided to take some action.
oil had began to seep down into the spark plug area so following instructions on S2-audi.co.uk
(sorry, couldnt find any on the forum) removed the cover and fitted the new gasket kit.
Part no. A034 198 025 F
outer rubber seal seemed ok, but inner rings around the spark plugs had baked solid
which explains why they were letting throu oil. had to be broken off from
cam cover.
Also found earth strap at rear of cover was loose, so all in all a job well worth doing.
Brian
so finally decided to take some action.oil had began to seep down into the spark plug area so following instructions on S2-audi.co.uk
(sorry, couldnt find any on the forum) removed the cover and fitted the new gasket kit.Part no. A034 198 025 F
which explains why they were letting throu oil. had to be broken off fromcam cover.
Brian
Pulled the plug covers for Jas to check my spark plugs and they made a rather alarming squelching noise as I pulled them free - sure enough most of the plug chamber was filled with oil!! Eek!
. could do that before inters, dont fancy changing the rad again.lol
, particularly at the front end near the cam pulley. but with patience can be done eventually. Just take your time and remember to torque up the allen screws in sequence.
