7a cam timing
  • 7a cam timing
    hi im new to this lark ,..............can anyone tell me if the 7a cams need to be timed differrant to the standard cam on the 3b engine ?..... .i have put the inlet/exhaust cams on my audi s2 turbo which has the 3b lump and kept the same timing.........is it ok ................. it seems to be a little rough at 20,000 rev,s
    At 20,000rpm, you are 1,000rpm of the the limit of F1 cars so no wonder it is 'a little rough'
    Cheers n
    Si
    95 ABY S2 Coupe - Ragusa Green
    Subtle mods here and there
    2011 A5 3.0 TDi - Lava Grey
    With every option available (except a towball)
      Hi
      new to this also, but did you change both?? Is there not a mark on the two, and if they are on their marks, this should be right?? I think so??
      japanischer industriabfall nein danke!!
      www.rackeltrim.se Icelandic Division
        The 7A cams don't need to be timed differently.
        SS
          Same as stock! Very important!
          2004 9-5 aero
          2009 Subaru Legacy Diesel
          1994 Toyota Supra Eurospec 6-spd LHD
          3-4 Audis in parts
            faster than an f1
            yer i see what u mean .............20,000 rev,s ...................what about 2000, revs and a little rough......................prki
              recognise the name..did you sell that 5 branch manifold?
              93 S2 Avant Parting
              91 URQ RR
              02 A4 tdi Avant
                what. bhp................?
                still have it night rider..............can u advise me ...?,...............what bhp can i expect from 1991 s2 tubo b4 lump ... with bmc induction /performance exhaust no cat.. 7a cams rs2 standard manifold ..rs2 k26 turbo ..............not remaped..yet
                  max 380 or so.
                  Go Holset or Go RS4
                    I would only use the 7a exhaust cam, unless you want to zip your coffee each time you wait for the turbo to spool
                    2004 9-5 aero
                    3-4 Audis in parts
                      Why do you say that? I have a 7A inlet with 7A exhaust and it seems fine.
                        To much duration, not ideal for a forced induction engine. Better off with some shorter duration cams with plenty of lift.
                          Could you Pm what you are wanting for the 5 branch
                          93 S2 Avant Parting
                          91 URQ RR
                          02 A4 tdi Avant
                            5 branch exhaust
                            hi im looking 4 £75.............................cheers prk53
                              It all depends on the setup of rest of engine......
                              A couple of good questions is:
                              - why isn't the extra duration ideal for a forced induction engine ?
                              - what can be done to the engine setup to make use of the potensial the extra cam duration gives?
                              Cheers,
                              Roger
