Hi Guys, I quickly knocked up a little box to read Blink Codes when I cant be bothered to get VagCom hooked up.
I was thinking, as the parts only come to about £4 in total how about I make some more up for say around £6+p&p, with the £2 extra per unit going back to help fund this forum. I have no idea how much it costs to keep the forum going, but as Tesco says, "every little helps". Maybe charge even more per box?
It would be great for peeps who do not have VagCom to keep in their glove box. I guess those that do have VagCom could even keep one in the car when they are out and about.
I know that it is easy enough to go out and faff around with some paper clips and a 12v LED, but if you are away from home you wont have these bits to hand and probably wouldn't remember how to connect it up!
The finished unit will be finished in a durable black ABS box (50x35x17mm) with a big square switch, and a 5mm led. There will be 4 colour coded wires, terminated with mini spades to push into the Diagnostic sockets. A connection diagram will be printed on the back, and some simple instructions on the front.
What do you guys think? Sorry if it is a gimpy suggestion
Some pics of my box (The new ones will be smaller and the 4 wires will be better quality!)
