I have had the old problem of false (!) alarms after a period of non use on the previous S2 & the RS2. The only time it was true was due to a hydraullic fluid leak from the pipe out of the hydraullic fluid container.
Now the car has had new front discs & brake fluid service. The alarm goes off over every bump!!
All the levels are OK. How does the brake fluid sensor work ?? Does it detect pressure in the system or just low levels or high levels ??
