Brake fluid level sensor
  • alg
    • Apr 2004
    • 1160
    I have had the old problem of false (!) alarms after a period of non use on the previous S2 & the RS2. The only time it was true was due to a hydraullic fluid leak from the pipe out of the hydraullic fluid container.
    Now the car has had new front discs & brake fluid service. The alarm goes off over every bump!!
    All the levels are OK. How does the brake fluid sensor work ?? Does it detect pressure in the system or just low levels or high levels ??
    Alastair
    RS2
  • Mikes2
    • 1704
    There's 3 sensors which can trigger this.
    Hydraulic fluid level sensor
    brake fluid level sensor
    hydraulic pressure sensor
    I had an issue with the brake fluid level sensor on my 90 quattro 20v. Disconnecting it got rid of the warning but replacing the plastic slider at the base of the reservoir made no difference.
    Ended up replacing the reservoir with a 2nd hand one as I couldn't get to the float.
    Mike
    http://www.s2-audi.co.uk
    • alg
      • Apr 2004
      • 1160
      How easy is it to replace ? Why could you not get to the float ?
      Thanks Mike
      Alastair
      RS2
      • Mikes2
        • 1704
        The reservoir just lifts up from the master cylinder. You need to clamp the clutch feed hose and have some rags around to catch the fluid.
        Couldn't get to the float as my fingers couldn't reach into the reservoir. Even after removing the gauze protector, there's not much access.
        I take it you've verified the brake fluid level sensor is the culprit
        Mike
        • alg
          • Apr 2004
          • 1160
          Well in as much as the bomb passes its test & all fluid levels are correct. In addition it seems to come on going over a bump or turning at low speed. Suggests a fluid level shift is causing alarm rather than pressure.
          I will verify by removing the sensor connector (checked it a few times re good contact)
          Alastair
          RS2
          • Fat Audi 80
            • 10547
            Al, I have had that on the PS Fluid reservoir before, it seems the actual connection to the lid of the bottle was dodgy. Undid the lid and did it up again and it was okay.
            Have you checked this too?
            Kind regards,
            Steve.
            (I guess it probably is the Brake Reservoir, as the has been recently worked on, but worth checking both...)
            The Perfectionist
              Also check the PAS float isnt getting stuck, you should see the nipple poking out of the top of the reservoir
              • alg
                • Apr 2004
                • 1160
                Well seemed to sorted this by 'thumping' the brake fluid reservoir..........no alarms since. Me thinks a sticky is in order. If you get the old red (!) & the bomb passes & fluid levels are OK, just thump the reservoirs !!!!!!!!!!!!!!!
                Alastair
                RS2
                • BrianSmith_S2
                  • Jun 2005
                  • 1342
                  • Home: Northern Ireland Current: British Antarctic Territory
                  Or unscrew the cap/float assembly and give the contacts and switch a good clean (i used carb cleaner) ensuring its dry before its refitted to the reservoir.
                  I recently got this alarm when starting the car first thing in the morning after i had bled the system and overfilled the reservoir. i think the fluid had got to the cap and messed it up inside.
                  After the clean, and removal of some fluid, its been ok since
                  • alg
                    • Apr 2004
                    • 1160
                    Brain are you not referring to the Hydraulic fluid reservoir ?
                    Alastair
                    RS2
                    • BrianSmith_S2
                      • Jun 2005
                      • 1342
                      Yep...thats the one that was causing the (!) to come on. as mentioned a few things like low pressure, low brake fluid and low PAS fluid level can set this off afaik
