Has anyone got any good links to explaining cam and crank timing?
I'm failing to grasp a concept here that Pisobiker has done with the stroker.
He states that because the block is 16mm higher then the cam / crank timing will be different.
But if the cambelt belt is the same length as OEM in both configuration how is this so?
As the belt is what links head to block and as the belt length is static surely the timing is no different?
