Cam timing guides
Carlos.
On the look out for less bits for my s2 saloon project. Now supporting myself by shooting for my food. www.airgunforum.co.ukComment
Paul how do you check this, Vagcom?@Jamo - you are absolutely right to ask and check this stuff - get a timing wheel and some time on your hands to take the measurements to assure yourself that the cam timing is what it should be...
Its only when the engine is running that you'll see if the timing pulses are in spec - the crank reference pulse MUST arrive within every other hall window - ideally in the middle of it but not crucial AFAIK. Actually with the engine on a stand you should be able to visually confirm if things are aligned.Comment
Old thread, related question. Wich 2.5Tdi blocks has the tensioner holes?Comment
I don't think the Tdi blocks do have the holes, the aux roller is on the oil pump like the 3B. If you want to do it like Jamo you'll have to drill and tap the block.sigpic
1976 RD250E / 350LC cafe racerComment
To me it sounds like Jamo had the holes stock in his block?Comment
I was told they were there by default, I reckon Andy is right and Pisobiker tapped them. AndyP retapped them for me when he helped me out with the build so we had a mofo of a bolt on the tensioner.
The 3B method is definitely easier but the way mine has been done allows me to run an RS2 water pump which I think is a good thing in a block which potentially is holding a greater volume of coolant.Comment
