Is the front pulley weight the same in 3b/aby/aan ?
the problem is that the stock engine crank is not balanced at zero. So to play safe you have to use stock front pulley and stock flywheel that are also not balanced to zero. But together with the crank they are perfectly balanced.
I was told by Aelred that ABY and AAN are different also, I was looking to get an AAN one he was selling as a spare. Not sure what the differences are tho having not compared them.
Yeah AAN uses different belts so the pulley grooves are different.
From a previous thread on alloy front pulleys, I think the outcome was that you need to keep the pulleys with the crank they were designed for, i.e. ABY crank requires ABY pulley, I think it was also true that this was independent of which flywheel was used as the pulley damps the crank rotational vibration after the FW because the FW is attatched to the large mass of the drivetrain and thus car.
keep the pulleys with the crank they were designed for, this was independent of which flywheel was used as the pulley damps the crank rotational vibration after the FW because the FW is attached to the large mass of the drivetrain and thus car.
+1
The pulley is an harmonic vibration damper. Altering the weight means you change the balancing frequencies.
I've seen some hard way learning on an engine dyno were the IL5 TDI pulley (dual mass) ripped next to the vulcanised rubber.
Dyno operator confirmed the shivering was noticable on 'x', '2x', and '3x' rpm.
