Hi everyone
I need a reasonable solution for brakes for now. Porsche calipers are out of the question. I happen to have a rebuilt set of A4 single 57mm piston calipers. This is what they look like when they're bolted up on coupe quattro rotors drilled to 5/112. A4 calipers are meant for 288mm rotors. The coupe rotors are 276mm. They're both 25mm wide rotors.
If this was just a temporary solution and just to make the car brake for now. Could I reasonably use it until I get proper brakes on it? It's not a dailly driver and it's not going to be driven hard for quite a while. I may even have porsche calipers on it by the time all is said and done but I wouldn't mind driving the car to have an exhaust made for it or something along the lines. It would be easier than having towed. Plus the whole feeling of having a moving and driving car would be nice.
PS I wanted to run 312mm by 25mm A8 rotors with this setup and tt caliper carriers but the offset of the s2 hubs screws everything up. I may look again at it but i don't see it happening.
