Hi every1.
i am in search of someone that can do this job for me to perfection.
I already use a 70mm throttle body modified by Aelred which works fine, but it seems that a small slack that was left from the flap i presume for free movement or something,is allowing enough air to pass through to mess with my idle speed.Therefore my idle speed is unable to be adjusted to any level below 950rpm on normal conditions and the adjustment screw is not helping as well. Ignition timing needs to take over from that point as ISV being completelly shut does not alter the situation, and id like to have more room for calibration. I have noticed that on the rs2 TB that i have there is a total and complete seal of the flap.
Therefore, i have my old RS2 throttle body which needs to be machined to the 70mm mark and a flap inserted that seals 100% so that i can then readjust everything from the VEMS settings OR the screw.
I have already pmed Aelred for a second attempt as well as emailed him, but he may not have seen the request. I was wondering though if there is anyone else out there that can do the same job for me anyway.
many thanks
Vasilis
many thanks
Vasilis
