Anyone Good With Auto Boxes?
  • Anyone Good With Auto Boxes?
    I've brought an Audi S6 with a reverse issue when cold it won't reverse up an incline if its flat its not too bad, it just slips if you rev it in reverse all 5 forward gears are fine its also fine once the gearbox oil has warmed up. Everything I've read pointed to the oil so I've removed the pan cleaned it replaced the strainer and flushed the box with the new oil but the problem remains
    any ideas? I don't mind rebuilding the box (not looking forward to it mind) but I wanted to eliminate everything else first I'm now thinking it could be the valve block that's at fault but Audi state you can't do anything with that and just to replace it.
    I am also toying with the idea of converting it to manual
    Anyone??
    URQ 20vt converted
    80 quattro saloon with on going a V8 transplant
    One on gBay! Item no:230640960308
    Audi Nut!!!
      No good for mine mate unfortunately it's for the older model.
      URQ 20vt converted
        Go for Manual,you won't regret to go for that.my completed conversion parts will be arrived from N.USA on the next few days.
        tired of AutoTragic Trans.
        one of a few I5 from Asia.
          Clutch pack broke down? Could be repaired but is usually expensive.
            I don't think its that as its perfect when the oils warmed up
            URQ 20vt converted
