I don't drive my S2 all that often but when I do I always check the oil and it occoured to me the other day that I'm always having to put a bit in. So I decided to check the consumption to see how much it's using. The figures are not good, it's using a litre of oil in 6-700miles approx. So here's what I know:-
-It does not smoke on start up, hot or cold
-It does not smoke on the overrun
-It does smoke, light grey, under hard acceleration
-A compression check shows all is the same as when the engine was built, all cylinders within 3.5%.
-Plugs are a little black, but it's a dry black soot not an oily black. It does run a little rich on WOT
-The turbo, GT3071R, was rebuilt about 3000miles ago due to worn oil seals.
I'm thinking that the turbo is defective again, but can anybody suggest any other checks I can do before I pull it and send it off for another re-build?
