I have a problem with the heating in my coupe
I have warm (not hot) air coming from the vents ! Have replaced Radiator, Thermo switch,Thermostat,Water pump,Heater matrix,Expansion bottle several hoses and bleed hose leading from matrix !
Absolutely no leaks and has been bled several times ! Heating is mediocre at best
Fans (stage 1 & 2) are kicking in at around 88c.
My mechanic is stumped and can only suggest it may need a Thermostat that has a higher temp range as I'm sure fans are not supposed to kick in till the 90 +1 and +2 stage.
Any help would be greatly appreciated
