As it says, starting a project to fit RS2 rear brakes on Coupe.
First and most important a big thank you to Roger (Audi_CQ)
Coupe rear suspension setup is different from RS2 one, wheel bearing are different diameter, wheel housings and hubs have diffrente geometry so some changes have to be made.
The most important change goes into the real wheel housing. It needs to accomodate the larger rear wheel bearing, the Porsche parking brake (drums inside the disk) the RS2 wheel hubs, the RS2 rear caliper Carrier an then calipers, brake disks and alloys.
From the original RS2 rear wheel housings there was some machine work done to bring the inside diameter and outside diameter (by adding a ring of metal) to the exact same values of the RS2 one. Also holes to mount the RS2 caliper carriers where done and the Carrier need it to be modified to adjust the caliper into the S2 position (in front of the rear suspension)
Here are some pics of the Coupe rear housings with all the modifications + powdercoating.
1st
1st
