K24 7000 360 hp
  • K24 7000 360 hp
    Got some new billet turbos
    K24 7000 with paper from dyno 360 hp and 505nm
    1.6 bar . (Mustang dyno) Original s4 intercooler . Stock engine 3" exhaust .
    750 euro
    mustang dyno sheet , power on the wheels .
      Pls tell us more about that turbo setup and how typical is a result like that. 500Nm is impressive for small turbo.
      What is included in the price ?
        I've pm'ed you. I'm really intrested in this setup and have Been looking for this for quiet some time.
          This is for turbo .
          Can get chips , injectors and map sensor .
          Have bigger turbos also . Buth no paper on them .
          If you puth on a bigger intercooler there might be litt better performance . Stock engine so this result should not be problem to achive
            I can't believe that 7000 can (at 1.6bar) give more than 300hp
            photobucket SUCKS
              Original it cant to more then 290 i guess .
              This have larger comp and exhaust wheel .
              Very nice upgrade .
                Very nice upgrade .
                I can't believe one 7000 tuned, can give like a 7400 but...
                photobucket SUCKS
                  That is wy i gave paper from test . it have 360 hp with stock intercooler on s4 , and 505 nm ..
                  Nothing to belive , belive you can do in church This is fact ..
                    Well, if it has bigger comp and ex so what's the problem?
                      Panthero CoupƩ quattro 20vt
                      Indigo ABY coupƩ
                        Does it spool faster than stock 7000?
                          Well, then it is no longer a k24
                          photobucket SUCKS
                            So why do you think is the K24/7200 from RS2 also a K24?
                            K24 turbine inducer is 59mm, but there are different ones. K24/7000 from S2 has 59mm/44mm, K24/7200 from RS2 has 59mm/53mm; There is at least a third version that has 59mm/51mm, I donĀ“t know where it is used (maybe Porsche GT2 or the volvos), so if you machine the housing out, and fit this turbine and a bigger compressor, it still is a K24 but can produce and handle much more power.
                            I only doubt, that it is a "7000" one
                              Hello.
                              What kind of chips can you get for a 3b engine?
                              Sent from my iPhone using Tapatalk
