brand new, good units, without turbine fitting issues:
CT355
57mm impeller
63mm turbine (stg5)
.63 A/r
triple ball bearing
aluminum center section
Ultra-quick spool up combined with 550hp flow capacity. Excellent turbo for daily use.
t3 turbine inlet
3 inch Vband turbine outlet
List price 1740 eur, this one 1040 eur
CT367
67mm impeller
63mm turbine
.63 A/r
triple ball bearing
Outperforms Garrett 35R both in spoolup and in peak flow. Multiple I5 setups run 600-630 hp with this turbo around europe. With bigger A/r turbine stretches above 650hp.
T3 turbine inlet
3 inch wband turbine outlet
list price 1740 eur, this one 1040eur
CT350
54mm impeller
57mm turbine
triple ball bearing
Brand new center sections, second hand housings
Excellent, drivable 450-500hp turbo for daily use
list price 1690eur, this one 850eur
pls contacts in email
CT355
57mm impeller
63mm turbine (stg5)
.63 A/r
triple ball bearing
t3 turbine inlet
CT367
67mm impeller
63mm turbine
.63 A/r
triple ball bearing
T3 turbine inlet
CT350
54mm impeller
57mm turbine
triple ball bearing
