Ct6165 Audi S4 on track
hi repo, i sent you a pm did you get it? -
How much damage to the engine? totaled?ShaneComment
It gave 580hp / 600something Nm last spring at 1,7-1,8bar, but we could not get the boost up, as the dyno operator was too afraid to apply the brakes, so the run took like 2 seconds.Everything less than 2 bar is considered to be naturally aspiratedComment
This engine has bone stock head with Schrick cams and valvesprings, and pretty aggressive timing on the cams, so I bet with original cams the max power could be even higher than 620hp.
The engine setup otherwise highights my manifolds and custom fuel system with twin 44's. Also exhaust system is custom twin 3in I made originally for bigger turbo. That setup gave 630hp/790Nm with 1.9 bar on rollers. Afterwards I blocked the wastegate and we drove around with three bar. After a summer the turbo was d-o-n-e done.
But generally there is no difference in S4 and S2 engines in this sense.Everything less than 2 bar is considered to be naturally aspiratedComment
exellent j, i first thought it was a s4 (2.7) engined one, seems very lively when on boost.This engine has bone stock head with Schrick cams and valvesprings, and pretty aggressive timing on the cams, so I bet with original cams the max power could be even higher than 620hp.
But generally there is no difference in S4 and S2 engines in this sense.Comment
