what power can wagner manifolds take you to
  • keithsw0
    • May 2005
    • 571
    if any body can teel me that will be great
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    Carsten has mentioned that the RS2 EVO can make 500hp.It has a bit bigger diameter from the SQ manifold and then the rest it is up to design actually.Im betting the 500hp figure (crank) is easily possible though
    • monstereddie
      • Dec 2007
      • 248
      I reached 414 with the KKK26/27/29.8 on 1.55bars hold and 1,70 OB.
      I will try a GT3082 or GT3076 on the EVO EM. I want to reach the 450hp, this is my goal. We should not forget, that i am running a 2.5l ADU Engine. I think, that it is possible to reach 500... We will see.
      THE BLOG ABOUT THE REVENTON GREY RS2 called BOMBER....
        It's all down to EGT's manifold will do 600 bhp crank IMO as it flows better than an SQ manifold and the SQ will get to 600 bhp with a 35/40
        I'm will be using one with a GT3076 .82 and 2.5l stroker
        • keithsw0
          • May 2005
          • 571
          manifolds
          thanks guys so to get 600 bhp are these the thing to get are you talking about im or em
          • aronmatic2
            • 2129
            • Country: Hungary
            i had more than 600hp with the chinese replica. i think wagner can do more.
            Real carbon parts for S2 and RS2. Check Carbondesign on facebook
            • Rusty
              • 18953
              • Lupo911
                • Apr 2005
                • 312
                Guys, not the Manifold is the Problem... the Power is limited by the Turbocharger.
                Actually, without any modification the biggest Turbo what will fit is the GT30.
                For more Power, i will come up with something in the near Future
                • audi4fun
                  • Mar 2006
                  • 111
                  • Country: Latvia
                  If I install RS2 EVO EM and GT30 or GT3071 do air filter box stays original one or should be replaced with cone? So the question is is there space enought?
                  Thank you!
                  Owner of www.audiScars.lv
                  ex-Audi S2 Coupe '96
                  ex-Audi S2 Coupe '93
                  ex-Audi S2 Coupe '91
                    Thank you!
                    It needs to be modified, there is one or two threads detailing the modifications required to the airbox.
                    • A80Avant
                      • Sep 2005
                      • 10873
                      • Country: Greece
                      yes a small modification is needed.
                      jamo do you recon that the 3076 is the same size in compressor housing so that the rs2 air filter can still be in place?
                      • Bram
                        • Aug 2006
                        • 2582
                        Yes, that should be about the same. I think only the inlet diameter is slightly bigger (76mm instead of 71mm), if I am correct.
                        • audi4fun
                          • Mar 2006
                          • 111
                          • Country: Latvia
                          Thank you! I love original look.
                            No the 3076 compressor housing is slightly bigger than a 3071. I wish I measured the 3071 when I had hold of one.
                            Mainly down to the 4" inlet on the 3076
                            • Bram
                              • Aug 2006
                              • 2582
                              OK, good to know that. I always thought it was just a difference in inlet diameter. I have a GT3071R in my car, so what would you like me to measure? The outside diameter of the cold-side?
