wagner tubular with v-band
  • GazzaG60
    • 4133
    Carsten
    hope things are good.
    instead of writing direct i thought id post it here. if i need to write ditect let me know.
    can you do a tubular with a vband connection to the turbo?
    is there a big cost difference.
    many thanks
  • Kieron20V
    • Mar 2008
    • 1505
    Do any manufacturers even make V banded hotsides? Ive seen V bands on the exhaust/downpipe, but not for the turbine inlet.
    1994 URS4 Avant RS2+
    • lind4hl
      • Jul 2008
      • 2465
      Yes TIAL does V-band
      • quattro
        • Dec 2004
        • 768
        Probably the longet S2 project in history EVER!
        • Kieron20V
          • Mar 2008
          • 1505
          Really?
          Ahh yes, it would appear they do, thats a pretty cool option, easy removal installation. Nice.
          • lind4hl
            • Jul 2008
            • 2465
            bah.. dont believe me??
            sorted
            gonna have it myself..
              Tial have been doing them for some time now
              • GazzaG60
                • 4133
                i use precision.
                most new oem is vband too.
                a manifold with no turbos would be oif no use to me lol
                its not about the removal its about the efficiency and lag reduction
                • bandit1
                  • Jan 2010
                  • 10
                  HKS T51 comes with V band hotside too
                  • Jon441cc
                    • Dec 2005
                    • 2061
                    Maybe give this guy a shout gaz
                    It's for my UrS4, I built it from scratch (aside for the collector which was cut on a 5axis laser, and the head flange which was cut on a waterjet). Head flange is 1018 mild steel, the rest is 1.50sch 10 304 stainless. It's somewhat "equal length" two runners are about .75-1.00inches shorter...
                    • LYT4X
                      • Jul 2008
                      • 177
                      Excuse the ignorance here.......
                      What 'exactly' is V-Band? I'm guessing it's a type of fitting for turbos to avoid using jubilee clips on hoses???
                      John
                      A Small Collection...
                      • GazzaG60
                        • 4133
                        its fitting type.
                        basically 2 circles that clamp together with a special clamp.
                        what it allows is a different design hotside. there are debates over its benifits. you will see the likes of motor manufacturers using vband turbos now.
                        the next turbo i will get will use this type of setup. suppose i could just have the wagner modded locally to suit.
                        hks turbos as mentinoed in an above post tend t obe mortgage specials. hks do some nice stuff but usually at a premium. ill be going with a precision turbo again...when i do it.
                        • LYT4X
                          • Jul 2008
                          • 177
                          I'm going for a new GT2868 BB unit fitted with a 34mm restrictor.
                          It may seem small, but there's little point in going for a huge turbo when you are going to choke it anyway. I need low down torque for gravel stages.
                          John
                          • GazzaG60
                            • 4133
                            thats fair.
                            the precision units seem to be very efficient from low down an d hold on well too.
                            i want more lower end and better low boost power but still to hold out. or m aybe a bigger unit with the same mid range as now but more up top... choices, choices eh
                            • a4kquattro
                              • Feb 2005
                              • 411
                              Not to let the cat out of the bag too early, but EFI Express will soon be offering a high quality 20vt tubular manifold with V-band turbine outlet, spiral collector, and tial 44mm wastegate flange. We expect to have them ready late February early March
                              Marc Swanson
                              Proprietor, EFI Express
                              95.5 //S6 Avant
                              90' Coupe Quattro V8 4.2L twin turbo
                              93' //S4
                              83' UrQ
                              97' F250 7.3 diesel
