intake
    As said there are two types of bonnets, Pogea confirmed as well he's had the same issues on his installs.
    • GazzaG60
      • 4133
      do you know what the difference is?
      i saw numerous wagners at gatebil and none had the bonnet cut.
      • madpugger
        • Sep 2007
        • 1901
        I have a cr@ppy fake bonnet. I would like a genuine one if anyone has one, but will let you know how the IM fits on mine fairly soon
        Le Mans 2012
        Nurburgring 700
        1995 S2 Avant
          There's a bump that the throttle can get past but when it trys to close it will stick against it and jam open.
          • GazzaG60
            • 4133
            mines like that.
            it sticks at about 3/4 throttle.
            i used a panel hammer and trimmed the cable carrier.
            • Bram
              • Aug 2006
              • 2582
              mines like that.
              On my S2 ABY I had the same issue, however I don't mind removing some stuff from the inside of the bonnet to get the advantages of the reverse intake
              • GazzaG60
                • 4133
                i removed all the front plastics. no problem.
                then it still didn't work on the throttle.
                i trimmed the cable holder corner and flatenend the lump on the underside edge of the bonnet.
                i used some paint pen type things to colour in the cable carrier which is the bit that catches to see where its full span of movement was.
