Wagner SQ EVO Exhaust Manifold
  • caterpillar
    • 2480
    does you hane some flow chart on the new EM.. to compare with thee others; some tests?? intr manifoil...
      Post 7
      • S2 Ant
        • 3682
        Originally posted by Jamo
        OMG how sexy are they?
        Definitely on my upgrade list if I change turbo
        Will you ever use the one you've got tho?
        Ant
        2011 Kawasaki Z1000
          I use the one I got everytime I drive the car!
          • A80Avant
            • 10873
            • Country: Greece
            #20
            it would be interesting to see a flow comparison of the actual new one with the rs2 evo.(not the casting equivalents)
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              #21
              surelly it is enough (for the moment) for you Vasilis with the RS2 EVO manifold
              and if the sport quattro EVO manifold flow better the air....
              wich are the advantages of the sport quattro evo one with the WAgner tubular T3 manifold...that it is recomended for track cars...because surelly flow a far better and you have to mod the original downpipe position .... and the tubular one it is far cheaper too
              • A80Avant
                • 10873
                • Country: Greece
                #22
                i have a SQ Em at the moment, which does the job and EGTs are low. Surely the EVO SQ is going to be much better.
                • JP
                  • 1858
                  As a reference point most I5 ported heads I've come across in the market place will flow around 175-185cfm@28" on stock sized valves. I've seen 190-195cfm@28" peak figures on oversized valves with more area under the curve.
                  Over sized valves with welded up and reprofiled exhaust ports have yielded 200-204cfm@28" peak figures with again more area under the lift curve.
                  So assuming that the posted flow figures are at 28" and the transitions are nice from head into the initial runner entry then you will be hard pushed to max out this exhaust mani hence my personal interest.
                  As for my personal opinion of cast vs tubular (not necessarily correct and open to other opinions of course)
                  The theoretical advantage of a tubular is that it will offer a more consistent delivery of air throughout a revolution of the engine giving smoother spool up low down and reduced EGT's at the top end due to a reduction in turbulence as the gases meet at the collector. In the same token the cast manifold has a greater ability to retain heat and will offer higher gas speeds again improving spool up, it's downfall being at the very top end of a high hp motor (700+) where too much heat retention can be detrimental to EGT's. So unless going full on top end race motor it's much of a muchness other than that the cast is theoretically much stronger and longer lasting for road use.
                  UrS6 Stroker + HTA3586 =
                  • Rocco
                    • Aug 2007
                    • 6393
                    • Country: Spain
                    #24
                    great explanation ,so the tubular manifold it is not a bad option for someone with 400/500hp ,the tubular ones dissipate more heat than the cast ones in the engine bay Ok¡¡
                    Vasilis we dont know if your original sport quattro manifold flow better than the RS2 EVO??
                    • A80Avant
                      • 10873
                      • Country: Greece
                      #25
                      that is true as Jamo says, that the RS2 EVO flows better than the original SQ. I liked the idea of longer runners than the rs2 evo, as well as the fact that i bought it cheaper as well!
                        Carsten from the 1st page is the new SQ EVO only available with a T3 flange and no K26?
                        • Lupo911
                          • Apr 2005
                          • 312
                          Yes, only t3 flange...
                          • 5banger
                            • Aug 2009
                            • 19
                            update...
                            everything on schedule?
                            • GazzaG60
                              • 4133
                              carsten
                              as you know i run the tubes.
                              do you have comparitive flow charts and roughly how much difference is in the turbo placing.
                              • Lupo911
                                • Apr 2005
                                • 312
                                Originally posted by 5banger
                                update...
                                yes, everything is cool, first manifolds at the machine shop...
