I bought such a turbo manifold by Wagner tuning, but I have trouble fitting the turbo to my manifold .. my turbo is a Garrett gt3076r 0.82, exhaust housing goes against my beam. Should I move the engine forward or put shims under the motor bracket on one side or have other suggestions? Regards Henrik
EVO RS manifold ..
I had this on my coupe with the OEM RS2 manifold and .63 hotside on a GT3071. Replacement of the engine mount raised it but it still rubbed the chassis when cornering. A few large washers to space the engine up another 1/2" does the trick.AUDI - saving Dad's from minivans since 1994
Unless you've got a stroker in which case you can't
I will eventually have the chassis leg recessed, I used a large hammer to remodel mine
I agree this is the way to go. I have a GT3076 / 0.82 with a Wagner T3 manifold.
I pulled engine forward as far as possible and raised that side. Wagner Eco t3 and ct355 .63. Not the same but it worked for me.Comment
I did not bump the beam (chassis leg). I raised (shims) the engine and moved it forward on it's mounts. You need to also raise the gearbox mount with shims.
You may have to bump the beam as your turbo is bigger?Comment
