video!!!
so what wastegate do you need to make that sound?Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim
& 2 bar! -
It's BOV with whistle on itOriginally posted by s2_southwestso what wastegate do you need to make that sound?
Sau200 20vt 88' 3b, human carrier
CQ typ85 with AAN inside, see project blog at http://kwlw.blogspot.comComment
stock WG then?Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim
& 2 bar! Comment
Wastegate (exaust gases valve), can make only scream which goes louder when the boost rises to the max if "equipped with screamer pipe". That rice sound is produced by the BOV whistle (don't mix it with turbo chatter - big boys have).Originally posted by s2_southweststock WG then?
If you don't get it from text - here are the pictures:
Wastegate is that mushroom which grows under bonnet:
BOV with whistle (trumpet to make sound louder ant more pleasant):
Wastegate screamer pipe (small exaust tube which is for WG output gases only):
