daschboard problem and automatic climate
  • Markmark
    • Mar 2020
    • 27
    • Country: Italy
    solved the problem was the light switch that seems to make contact with the climate control
    • Markmark
      • Mar 2020
      • 27
      • Country: Italy
      This gallery has 2 photos.
      • Markmark
        • Mar 2020
        • 27
        • Country: Italy
        other question, this can be connected as you want I have in a verse?
          • Dec 2017
          • 5984
          well done.
          Not 100% sure what you are asking, do you mean in reverse? I would put it back as it was, 're do the wires and use good heat shrink insulation to make good.
          • Markmark
            • Mar 2020
            • 27
            • Country: Italy
            #20
            you put it back as it should but the yellow / black and purple / black wires have a direction towards the sensor?
              • Dec 2017
              • 5984
              I had a search for you and this post has the schematics for auto air con. Hope it helps.
              • Markmark
                • Mar 2020
                • 27
                • Country: Italy
                #22
                settled the wires now I kindly ask if any of you knew how to solder them to the iat g42? i have two wires black purple and yellow black Thanks again
                • Markmark
                  • Mar 2020
                  • 27
                  • Country: Italy
                  #23
                  https://www.s2forum.com/forum/techni...rol-schematics
                  • Markmark
                    • Mar 2020
                    • 27
                    • Country: Italy
                    #24
                    Thank you very much
