Question about 96 mod S2
  • Eivind
    • Apr 2008
    • 41
    • Country: Norway
    I have heard a few times that the 96 mod S2 shares gearbox and running gear with the Rs2, does anybody Know if this is correct?
    -Eivind
  • fish
    • Aug 2007
    • 2333
    They have the wide 1,st gear, thats all i know. but feel free to correct me if im wrong. it came on the late 94 models and was so on till the end in 96.
    www.garaget.org/fish for more pic“s of my cars
      The RS2 came with a six speed "CRB" transmission with the wide, flexible 105H first gear shaft. Gear ratios, 1 through 6 were: 3.50 1.89 1.32 1.03 0.86 0.71
      The ABY S2 coupes came with a CGR six speed transmission with the same gear ratios as the CRB. Up to build date 5/95 or Trans serial number 77643, these CGRs came with the 01E 311 105 E narrow but flexible (to take the torque on launch without spalling the first gear teeth). From 05/95 to 12/95 (should be trans serial numbers above 77644), the S2s came with a CGR that had the 01E 311 105 H wide flexible first gear shaft of the RS2s CRB transmission.
      Ref: http://www.elektro.com/~audi/01E/ind2.html
      As for the other "running gear" obviously, the hubs and brakes of the S2 are different than the RS2. I suspect brakes and shocks are different too.
      • Eivind
        • Apr 2008
        • 41
        • Country: Norway
        Thanx, so if I understand this right it comes with a S2 gearbox with same gear ratio as an RS2, and with the wide 1. gear as the RS2?
          Only if the transmission serial number (SN) is > 77644. Just assuming the build date > 05/95 = 105H isn't good enough. You need to check the trans SN to confirm.
          • Eivind
            • Apr 2008
            • 41
            • Country: Norway
            Mine is built 08/95 I think, but I guess I`ll have to check the serialnumber on the gearbox..
            Another qustion: Anybody have a clue what vin/chassis number the 96 modell start and stop on? Would just be fun to know what number in the line mine is..
            • anton
              • Jan 2005
              • 802
              as URs4boy said year doesnt tell you everything..need to know when it was build not when it was put on the road, some of them could be over a year older than the reg states. vin is the only way to know. guy at uni has a 96 reg mk2 golf lol stopped making them in 91 or something lol
              Ant
              91' Coupe quattro 20v - project
              KW V2s and other goodies
              now gone
              03' BMW 330CI - Sold
              08' A5 Coupe 3.0l tdi quattro - Sold
              57' BMW 525d M Sport Touring
              • Jas11n
                • 5067
                2001 Avus Silver B5 RS4.
                1995 S2 Coupe - sold (sniff)
                  Jas you big show off!
                  • HPmuirt
                    S2Forum April Fool
                    • Apr 2005
                    • 3014
                    I was of the understanding that the late S2 boxes shared the wide 1st gear with the RS2 box, but NOT the flexible shaft.
                    Cheers n
                    Si
                    Subtle mods here and there
                    2011 A5 3.0 TDi - Lava Grey
                    • Eivind
                      • Apr 2008
                      • 41
                      • Country: Norway
                      having used S2 central`s vin decoder I was pretty sure it is a 96 mod. I thought it was built 08/95 but it seems it was built between 05/95 and 08/95 since the vin number is 001300..
                      and as I said, I guess i`ll have to check the serial number on my gearbox..
                      Thanx for all your help and know how guys
                      -Eivind
                        Originally posted by HPmuirt
                        I was of the understanding that the late S2 boxes shared the wide 1st gear with the RS2 box, but NOT the flexible shaft. Si
                        If you check out the link I gave in one of my posts above, you can see that the info suggests your understanding is wrong, i.e. the later CGR S2 boxes got the 105H wide AND flexible first gear shaft not the 105J wide (and not flexible) first gear shaft. Have a look here:
                        If you have better documentation, please share.
                        • |CL|NIKI
                          • Jun 2008
                          • 380
                          • Home: Bulgaria Current: United Kingdom
                          What this "flexible" shaft means?
                          800HP 800++Nm
                          • Zoig
                            • Sep 2008
                            • 555
                            REVISION NOTE: 1/12/03 - in previous versions of this document, I've refered to a hardened and a non-hardened 1st gear. This comment about "hardened" was based on my (incorrect) assumption that the part numbers for the engines with higher torque used an extra surface hardening for reliability. I have recently found that the higher torque engine applications had a necked down mainshaft that would flex a little bit, thus keeping sudden torque impacts from loading the gear surfaces quite as much. Here are pictures of both types of mainshafts . Please note that the description "flexible 1st" is talking about the necked down versions of the mainshaft, which would permit a bit of "wind up" upon sudden torque load. Thus this main shaft was acting like a torsion bar spring in a suspension.
                            • |CL|NIKI
                              • Jun 2008
                              • 380
                              Super - so now I realized I got a wide+flexible first gear CGR - 77657 number .
                              800HP 800++Nm
