Poor idle on Audi tt ARY changed coil pack plugs and maf still no better anyone any ideas wot might be the problem
Poor idle
Tags: None
pull the throttle body off an clean it, this WILL help massivley
As stated the vac pipes under the metal plate by dipstick split, as do the oil breather pipes and will cause extremely rough idle.
If you clkean throttle body make sure you adapt it afterwards with VCDS,it takes two minutes. Don't listen to anyone who says it will learn the values etc. The Pentontion-meter will need reset to basic settings and should idle very nice after.Comment
