anybody on here done a s2 audi 80 quattro b4 sedan
Mdz, don't You know, which hub for 82mm bearing is the highest?
At ours it is popular to use UrS4/UrS6/V8 hubs for front conversion. They are told to be about 4mm lower than B4 front ones. The UFO ones are told to be about 2mm lower.
Out of your picture I see that 100 C4 rear hub is higher than B4 front one.Comment
V6 and the 4cyl/5cyl are the same except for the front hubs wich have the v6 has the larger 82mm bearings and hubs while the 4cyl and 5cyl have the smaller 75mm. Its all interchangeableComment
Because noone wants to waste their time in researching.
For 2.3 front there are two options - B5q rear hub plus ~2mm spacers between hub carrier and caliper carrier to center brake disk or machined C3q/C4q rear hub, V6/S2 hub carrier with 82mm bearing and C4 2.0 fwd outer CV joint.Comment
i would like to thank everyone who put some good ideas on this thread
maybe some how we could all put what we have done to convert suspentions and what parts works and what dont into a thread so its easy for other people to find info easy instead of trawling threw 100s of different threads to get answers .i am shue i am not the only one with these questions .Last edited by micky; 12 July 2014, 15:50.Comment
They don't send hubs separately.
