The drag cars new motor setup looks pretty cool tucked in there nice and snugly. it is all stock bottom end with ARP hardware only. i had to do .020 over oem pistons though due to cylinder wall wear, it is after all a 223k mile motor my engine guy wouldnt let me go Sloppy and just change the oil pump, he made me do rod/main/cam bearings and rings. all i WANTED to do was gap the stock rings for some boost haha. the grand total for the full build? parts were (for all bearings, rings AND PISTONS) $216, and i took a weeks vacation and spent it at the shop working on my stuff or his, whatever was needed. go in at 5AM, work til 4PM daily for the week. originally i just got ARP head stud kit and crank bolt/cam bolts, but he made me get ARP rod bolts and then gave me a set of ARP main stud kit. it is built as much a stock block can be without replacing rod/crank/piston with upgraded parts. i think it would sustain >1000 whp with ease with supporting hardware: IE turbo, fueling, etc.
so its a 5.3L iron block with 241 car heads, cut down .025 to bring back some compression. i hand ported the heads myself, and built it at the machine shop all me with guidance. he did the bore/hone/diamond plateau brush finish and i learned to run the head surfacer machine on my heads. i did the valve job myself too. heads have dual valve springs with stock valves, new LS7 lifters and pushrods, and the cam was custom ground to match the "small" (for LS anyways if single) turbo.
in all honesty, hardware (turbo and injectors (67mm and 1000cc)) should limit it to maybe 600 whp? possibly more, who is to say until its time right?? the 4cyl ran high boost at >47 psi, but used 4 x 2kcc injectors same turbo high rpm. this will run lower rpm, lower boost, same fuel @ 8 x 1kcc. so i dunno.
main goal is to learn RWD launching/driving in prep for the big tire tube chassis car, and have FUN with going slower, going rounds, more reliability, less work and less safety gear. helmet, jacket, run rounds is what i want.
Wheels and tires
Sent from my SM-G930V using Tapatalk
Wheels and tires
