hello, maby wrong place, i just try, i have vems v3 pnp for my urs4, i want to got more boost, are boost adjustabe or is it 3 bar map? I got new setup for my engine and want more, if someone can please tell me? I try google.. only ****,
Vems v3
honestly, it doesn't sound like you should be trying to do this yourself.... I would suggest you get someone who knows VEMS to make adjustments for you...Honda CBR 1100XX Blackbird Turbo....undergoing major changes.....
'03 ZX12-R daily hack.... lots of nice bolt ons...Comment
OEM MAP sensor is 416kPa, so you can setup boost in VEMS up to 3,16 bar boost (416kPa atmosphere). If it cuts at 2 bar there are probably some safety limits in your tune. If you send me log I can tell you.[__]=oooo=[__]Comment
Check in the setup under safety where your boost cut is set. Most likely it's close to around 300kpa therefore once you try and 'ask' for more boost you are reaching your boost cut limiter. Raise that to 340+kpa, add a line of fuel+timing for that boost on the equivalent tables so that you can have values for these targets and then you can tune itComment
, where in vems Adjust?
