Recaro resurrection
    • Dec 2017
    • 5992
    Recaro resurrection
    I recently acquired a pair of Recaro seats. They were in Charlie's (Cardcrash) RS2 which was sadly written off after it rolled. The passenger seat is in very good order and cleaned up nicely. However, the drivers seat is badly bent in the base, back and runner. The leather did somehow escape unscathed.
    I stripped everything down to assess what could be 're used. After much head scratching, I decided the base and back were beyond repair. Recaro seats are welded and riveted together which makes disassembled more difficult. The reclining mechanism in the back was completely mangled and the base so bent, not even Urigella would be able to fix it .
    And ad here didn't turn up spare parts.
    I noticed an advert on eBay for wanted any Recaro seats. Dropped the guy a line and he was very helpful. No RS2 or Cabbie Recaros, but he did have a Ford base and back that should work. They were duly purchased.
    On arrival, a quick inspection revealed that they would need some considerable work to convert. The side bolster supports are smaller, the base bolster supports are different and the back adjustment mechanism is different. They will work with a little cutting, welding and head scratching
    Pics conning shortly. We need a tea emoji
    • Dec 2017
    • 5992
    A bent runner
    A very bent base
    A very bent back
    The replacement base
    Let the cutting and welding begin.
    Someone has been here before me!
      • Dec 2017
      • 5992
      A bit more cutting
      And a bit more welding
      Nearly there. Lunch time. We also need a lunch emoji.
        • Dec 2017
        • 5992
        Base and back done. I just need to find a way to get the runner back in shape now.
          • Dec 2017
          • 5992
          The runner/ base is worse than I thought.
          I don’t suppose anyone has one knocking about?
          • struikie
            • May 2019
            • 314
            Wow, a lot of determination going on here!
            JW
            | project | 1993 Audi 80 VR6 turbo quattro |
            | daily | 2018 BMW G31 530d | 345bhp 770Nm |
              • Dec 2017
              • 5992
              JW
              I've started to question my sanity
              • LSG
                • May 2010
                • 897
                Really Dave ?
                  • Dec 2017
                  • 5992
                  Originally posted by LSG
                  Really Dave ?
                  No, just for a moment. I'm back on it now.
                  I cut the small welds out that hold the legs on and have 're shaped them off the frame on our old anvil. I just need to fit in the car runners to check I have the width correct, then I can weld in new supports ( which were very bent). Getting there hopefully
                    • Dec 2017
                    • 5992
                    Runner frame back together.
                    I put a stronger support on the left side.
                    Test fitted in my car and all good. Now I just need to put everything back together. Tea emoji
                    • david1980
                      • May 2014
                      • 1025
                      Good work there, especially from what they was like after the accident. Lmk if your planning on getting rid of them.
                      You can get the non electric versions of these every so often. I picked up a pair a while ago to have retrimmed.
                        • Dec 2017
                        • 5992
                        Thanks David. I already have a few people interested. These seats are getting hard to find.
                          • Dec 2017
                          • 5992
                          Just finished tonight.
                          • hilly82
                            • Jul 2019
                            • 104
                            looks spot on. I could do with trying to find some recarco's but i know thats not going to be easy! excellent work mate
                            • K Simmonds
                              • Dec 2007
                              • 7627
                              Just happen to stumble on this thread, I'm really glad you got them sorted. I knew it was going to be a pain but hell you put some work into this! I'd had as much of a look as I could without stripping the drivers seat down and came to the conclusion that the base would almost certainly need replacing but wasn't 100% sure. Though I thought the back should have straighted out, obviously I was wrong. As I said am really glad you got that seat fixed, don't think I'd have had the patience.
                              Sent from my SM-A115F using Tapatalk
                              1990 B3 2.0 80 quattro.
                              1992 C4 2.8 Avant quattro
                              1994 MTM RS2.
                              1998 B5 TDI quattro Sport.
                              2000 B5 TQS.
