RS2 flanged shaft question
  • mundo
    • Aug 2006
    • 36
    Hi everyone,
    I have about 1-2mm of 'play' on the off side of the rear diff on my RS2. The other side is tight, no movement at all. I've removed the flanged shaft (see pics) and the splines look ok to me? Is this the only source of play or is there something else I should consider? It seem these parts are unavailable new 016409355.
    thanks
    This gallery has 5 photos.
    • Dec 2017
    • 6006
    A little play is quite normal. But do use a new stretch bolt when you put it back. Still available from Audi.
    • B5NUT
      • Sep 2021
      • 1071
      Diff on my s2 also has a little play, also looks like your seal has failed.
      • mundo
        • Aug 2006
        • 36
        Well that's better than I expected. Just a new seal and bolt then...
        Thanks!
        • Bowie69
          • Nov 2013
          • 2681
          Bolt is unobtainable depending on diff type (some are longer than others....)
