Solar Charging!!
  • s20ale
    • Aug 2004
    • 476
    Solar Charging!!
    Anybody use the solar panel chargers?.
    Been bought one for crimbo but i'm not convinced they can be permanently pluged into cigaret l/socket, although there's an led to stop over charging.
    It just don't seem right pluging 12v/5w feed into car's sensetive electronics.
    I know the ideal solution would be to diss off the battery & connect directly but that kind of defeat's the object of the charger.
    What are peoples views on these chargers are they safe to use on the Audi or not.?
    All peoples views and comments appriciated.
  • terrybullwon
    • Mar 2006
    • 8782
    If your S car needed it, they would have made the car with it
    I dont see the point of one, i mean whats the alternator for?
    Just my 2 pence, i am sure its better suited to a boat (with sails)
    Chef
    • s20ale
      • Aug 2004
      • 476
      Alternator charges whilst engine running, Solar charger uses sunlight to condition battery when not used for long periods.
      • BRY
        • 3755
        It is an expensive option on the S8 IIRC.
        Do you want one yet?
        • terrybullwon
          • Mar 2006
          • 8782
          Like a hole in the head
          I guess if you leave your car sat for a long time it should be fine
          But dont forget we live in the UK
          Chef
          • Acidburn
            • 13459
            Yeah lucky if we get sun full stop.
            I thought you could get it on some of the extremely late s2's iirc jas commented on them on audifans once before.
            • Fat Audi 80
              • 10547
              Yeah there is a solar roof option that was about a grand!
              I think what the OP is getting at, is can you safely plug into the cigar socket and charge the car. I have always been sceptical about that sort of thing and don't know the answer.
              I have a ctek battery conditioner that I can plug directly onto the battery and it is excellent!
              HTH
              Cheers,
              Steve
              The Perfectionist
              • sjw185
                • 1175
                Think it quite a good idea im away offshore 3weeks at a time and currently use a battery isolator switch, never thought about the solar option.
                Plugging in to the lighter socket is not going to effect any electrics as the ignition and lighting etc are isolated through there switches when not used.
                Dont think you would have to worry about it overcharging but whether it actually made any odds at all.
                cheers
                • s20ale
                  • Aug 2004
                  • 476
                  HTH
                  Cheers,
                  Steve
                  Cheers Steve that's what i'm talking about, leaving solar panel plugged into lighter socket.
                  The other solar item people mention was for the sunroof which opens roof (automatic) & starts interior blower if inside cabin gets too hot, yes it was an expensive option & not much point in the uk climate.
                  My battery seems to lose its life if left for more than 3-4 weeks with alarm armed.
                  Just wondering if these type of chargers would eliminate the need of a isolator switch as SJW 185 ( ) mentioned which kills all electrics, also would keep alarm system and all electrics alive whilst not in use.
                  In theory it sounds quite a good idea for those that don't use their car as often as others.!
                  • shark_90
                    • 1475
                    Solar sunroof is/was available on the S8 and some other models (I know of a B6 S4 that had one) and it is not to charge the battery - it is to keep the blower running at a slow speed to circulate air through the car on hot days to keep the cabin temperature more reasonable.
                    I also tried one of these solar chargers as my 80 was sat for a long time. I found it to be a pointless waste of money and ended up buying a new battery (as it was knackered afterwards!) and a CTEK XS3600 charger for long periods of inactivity.
                    1994 Audi S2 Avant - in pieces
                    2006 Skoda Octavia vRS 2.0TFSi - goes fast
                    1985 Audi 90 quattro - is wet
                    Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
                    • Fat Audi 80
                      • 10547
                      Hi,
                      You need what I have:
                      http://www.vertar.com/ctek/ctek-multi-xs-3600/
                      This is brilliant. It even comes with a short plug with cables terminated with rings to allow you to connect to the battery permenantly and then just plug and play when you want to use it. I have installed this under the rear seat and cable tied the plug where the base of the rear seat meets the body. I only have to reach into the car behind the back seat to plug it in.
                      I HAVE to charge my S2 once a fortnight or the alarm will drain it. This charger can be left plugged in ALL the time too...
                      I can give you photo's of my installation if you want.
                      HTH
                      Cheers,
                      Steve.
                      Beaten to it by Shark!
                      The Perfectionist
                      • sjw185
                        • 1175
                        Hi,
                        HTH
                        Cheers,
                        Steve.
                        Nice bit of kit do you leave it plugged in when away?
                        Just thought it would mess with the door seals
                        Would like to fit some sort of recessed socket under the car if i was using it.
                        Still liked the solar idea though
                        cheers
                        • Fat Audi 80
                          • 10547
                          cheers
                          Yes, I leave it plugged in. The wires are fairly small gauge and do not mess with the door seal and fit between the back of the lower door strip and the rear quarter door strip. Will take some photo's if you want.
                          Cheers,
                          Steve.
                          The Perfectionist
                          • s20ale
                            • Aug 2004
                            • 476
                            I do like the ctek charger Steve but liked the idea of solar power, in this age of trying to be enviro friendly 'n' all that.
                            The ctek is very simalar to the optimate that i have for the bike, only problem is that it's permanently plugged into the wall & using electricity ( minimal i know ).
                            Just wonderd if anybody had used a solar panel for battery conditioning?.
                            Sounds like a good idea.!!
                            • Lupo911
                              • Apr 2005
                              • 312
                              i am charging with 22KW/h now
