I decided to do some logging in vag com after testing for any fault codes today just to see if anything was a miss.
Well it would seem it is .
I get a reading of 8.3 for throttle angle when sat at idle which I believe is a little high and at WOT it's 99.4 , the thing is is that it does not give the WOT Bin. 10100 ever when I'm getting 99.4 throttle .
The thing that is even more strange is that after studying it and doing more logging it seems to give WOT Bin. 10100 just as I open the throttle then it is back to 100 .
The idle switch is OK and I always get Bin. 10 at idle and Bin. 11 on over run.
I have tested the output voltage between pin 2-3 and I get 4.64v WOT an 0.39v closed, is this OK ?
I have moved the throttle very slowly from rest to WOT and I don't see any odd jumps in voltage.
Any ideas ?
Any ideas ?
